[CT] rear sway bar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
rear sway bar
Needing a bigger rear sway bar than what dinky stock one.. i'm running a 3/4" rear sway bar, and i cant even get bushings for it.. so i'm looking for something like 1 3/4"? Don't know the true sizes just something alot bigger.
shipped to 06489
shipped to 06489
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
Re: rear sway bar
The bushings are the same as the fourth gen camaro and are available anywhere. try www.Rockauto.com
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: rear sway bar
The biggest stock sway bars are 36mm(1.4") front & 24mm(.9") rear. Bigger is not always better & actually, some view the 19 as a better choice than the 24. Lack of weight transfer hinders sway bar effectiveness & reduces handling.
You certainly wouldn't want a 1.4" front/1.75" rear.
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
Re: rear sway bar
did you check out the energy suspension parts at autozone? i found my new end links there for my car
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
