Need Distributor/Single Fan
Old May 24, 2011 | 02:31 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
i need them for my 88 Camaro RS
Old May 24, 2011 | 02:52 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Need Distributor/Single Fan
I've got an OEM GM distributor. Small amount of surface rust, works great. No shaft play or gear wear. Get me you email address for pics and other info, Henry
Assuming you want stock remote coil model
This one has less slight rust than the one in my car, and just on top. The rest is real clean
Old May 24, 2011 | 03:46 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Oh yeah, are you looking for the whole fan set up, or just fan blade or housing? Motor kind of heavy to ship. Can get at most parts places
Old May 24, 2011 | 10:13 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
ThirdGen Single Fan: $20 + shipping. Be sure to post your ZIP code if you'd like a shipping quote !
Old May 24, 2011 | 11:42 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
you need distributor with module and cap and rotor and everything or just the distributor with pickup coil still on it? I also have a single fan
Old May 25, 2011 | 03:25 AM
pvr007's Avatar
Engine: 305 TBI
shipping to 92139, send me PM please
Old May 26, 2011 | 12:27 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
I did PM you.
Old May 26, 2011 | 09:49 AM
pvr007's Avatar
Engine: 305 TBI
i got the fan guys, thanks for all the offers
Old May 26, 2011 | 11:01 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
I got distributor with new ignition module and ill throw in a spare for 30 bucks shipped
Old May 26, 2011 | 03:05 PM
pvr007's Avatar
Engine: 305 TBI
im interested, but i have a core that is only missing a rotor and cap, if my core is tested and it comes out good, then i wont need one, but if they tell me that i do, ill buy it from you
Old Jun 3, 2011 | 09:31 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i have a distributor also, for the TBI v-8 engines.
be aware that there are two sizes of them due to different size hole in the intake manifolds for the mounting base of them
car and truck differ in diameter
ive found out the hard way in the past
you would think theyre the same as were all the HEI ones on the carb engines but nope they did something stupid dont know why and have two different sizes of distrib hole
crazy,,,
i have a good smaller sized hole one from a 1990 350
if anyone else is looking
the thing that happens to these is shaft bushing wear and it causes erratic ignition and so it runs crazy weird or stumbles or misses or dies or hard to start randomly
it is something to check if you know your fuel system is fine and also engine and other grounds and ign coil and ign module are ok as well.
the pure white pastey heat sink compound under the ign module is required, and not the clear cloudy gel looking dielectric grease stuff that they always give you with new plug wires and electrical connectors etc.
use the wrong stuff and youll overheat and kill the module
random stalling and or no start etc.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
