[TN] WTB: third gen rear disk brakes
Car: 1989 RS,
Engine: 355 sbc
Transmission: t5
Axle/Gears: 3:73
i just bought a 1989 RS and i would like to swap some factory disks on the rear. i can get vented rotors if need be,i just need everything else.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: WTB: third gen rear disk brakes
FYI: Swapping from drums to discs isn't a simple bolt-up affair. You'll either have to modify the axle flanges or purchase a 'kit' from Ed Miller, if you choose to use the more desirable PBR's (alum calipers and 11.7" rotors), which could be had on 89+ rear wheel disc cars. I wouldn't recommend the 82-88 iron Delco-Moraine version. Take note that you'll also need either a 1LE combination valve or an adjustable as well as parking brake cables. A search will provide much more info on the subject.
JamesC
Car: 1989 RS,
Engine: 355 sbc
Transmission: t5
Axle/Gears: 3:73
Welcome to TGO, wracks.
JamesC
JamesC
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
or
https://www.thirdgen.org/ls1reardisc
The latter has a better parking brake system.
Another option is the kit that eliminates the flange mod:
http://www.flynbye.com/catalog/i182.html
A search will provide a ton of info.
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TA8487
Aug 16, 2015 12:21 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
