[CA] WTB Rear End With Better Gears Than Mine
Old Sep 12, 2011 | 12:07 AM
WilliamSilver's Avatar
Not sure what ratio im looking for. Got the factory 277 i think they are? looking for something better i can just bolt up
Old Sep 13, 2011 | 10:07 AM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Re: WTB Rear End With Better Gears Than Mine
location?
Old Sep 13, 2011 | 10:28 AM
Sacramento ca
Old Sep 13, 2011 | 01:52 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
here ya go will in our area.
http://stockton.craigslist.org/pts/2577693146.html
http://sfbay.craigslist.org/eby/pts/2585511109.html
Old Sep 13, 2011 | 02:45 PM
I owe you a beer. Picking up the rear end this weekend in stockton I think. If.goingnfrom drum to disk it should be a pretty straight forward swap right? Old rear in out,new one in?
Old Sep 13, 2011 | 02:48 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I havnt done the swap but id imagine you have to change some lines on the rear end portion. also, a disc/drum proportioning valve would be needed. did you try and talk him down a few dollars at least?
Old Sep 13, 2011 | 02:54 PM
Offered 200. He said he'd think on it an to call on friday. Left a message at the other listing too. Think thats the best upgrade right now for the money.
Old Sep 13, 2011 | 03:03 PM
Just found a complete.lt1 for 150 with a bad bottom end as they stated. Hmmm
Old Sep 13, 2011 | 03:05 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
oh yeah I went from a 15.4 to a 14.7 with a 2.73 to 3.08 swap and a couple small things engine wise
Old Sep 13, 2011 | 03:08 PM
You swap the whole rear end.or how did you do it?
Old Sep 13, 2011 | 03:27 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah but i went drum to drum. not to drum to disc.
then when i switched to 3.42s I changed the gears.
But another thing. on the borg warner rear end. although it is a better rear end, thier is little to no aftermarket parts available for it, so if it has a problem it is hard to get it repaired rather than the regular 10 bolt in our cars are easy to get parts for.
Old Sep 13, 2011 | 03:31 PM
Yeah I was.just looking into that. Thinking I might just get gears and swap them into my rear diff. Or try to find a drum 3.4 rear end.
Old Sep 13, 2011 | 04:18 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
it'd be nice if you could find a nice posi unit for the 10 bolt also
Old Sep 13, 2011 | 05:10 PM
Yessir. What ya think,easier to find a whole drum unit or swap to gears and posi
Old Sep 13, 2011 | 10:01 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
its probably easier to find a 10 bolt with posi and gears, but you may end up with a worn out posi and/or bad bearings and all that...its cheaper to get a whole used rear end. but its better to buy new gears, new differential unit, and install all new bearings
Old Sep 14, 2011 | 01:20 AM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
9 bolts are way stronger than 10 bolts but it is hard to find replacement parts for it but on the other hand they made a thread on here all about the repair and modify of 9 bolts but if you stick with drum find the aluminum drums if you dont already have them
Old Sep 14, 2011 | 09:28 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
I just got aluminum drums for mine. obviously I cant tell a difference but id like to think the car is a wee bit lighter and faster haha.
Old Sep 14, 2011 | 03:03 PM
DiabloWS6's Avatar
you are right with the aluminum drums less mass and less unsprung weight on the suspension also helps with ride quality and performance handling
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
