astro van steering column bearing and retainer
Old Oct 27, 2011 | 11:50 AM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
hello, i was wondering if someone could help me out. i would like to get this part for my car but i am stationed in germany at the current juncture and american cars in junkyards over here is rare. even if someone knew of the part numbers for this. ive done some searching but came up empty handed. thanks for any help.
Old Oct 27, 2011 | 12:19 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: astro van steering column bearing and retainer
Maybe this:
http://www.autopartswarehouse.com/se...earing&submit=
I pulled a like-new Astro Van steering shaft from a Pick'n'Pull earlier in the summer for $8.99. Nothing for the bearing and retainer. If you can wait....
JamesC
Old Oct 28, 2011 | 12:10 AM
Eightyninef's Avatar
What is this part for? a 3rd gen?
Old Oct 28, 2011 | 06:11 AM
JamesC's Avatar
Yes. Info about the Jeep and Astro Van shaft (post #7), as well as the bearing in the link below:
https://www.thirdgen.org/forums/susp...ing-shaft.html
The link below shows a Safari shaft that apparently is a direct bolt-in:
https://www.thirdgen.org/forums/susp...y-u-joint.html
JamesC
Old Oct 30, 2011 | 09:01 AM
72vega's Avatar
Originally Posted by JamesC
Maybe this:
JamesC
damn i cant wait to get back to the states. i miss pick n pull so much. i walked out of one with an undamaged wrap around GTA spoiler for 8 bucks... next june cant come quicker.
Old Nov 3, 2011 | 08:26 PM
DSM's Avatar
DSM
Car: 84 Z28
Axle/Gears: 3.73 Torsen
The GM part numbers are
bearing 7805700
adapter 7805822
Stateside those two parts will run you about $40.
Most Jeeps through the 80s/early 90s used GM columns...and aftermarket replacement bearings for Jeeps are readily available. Check on-line with a Jeep parts place...you need a Crown PN# 4487696K which is a complete kit that includes the bearing, adapter, and the retainer ring & clip. I used this kit on my 84 Z28. You can find them on ebay for as cheap as $10, although you will also see them for $45.
If you want a rubber boot to cover the bearing, get a Crown PN #8132676K.
Old Nov 3, 2011 | 11:37 PM
72vega's Avatar
Thanks man! That was a big help. I looked on quadratec where I get most of my jeep parts and those 2 crown parts can be had for 30 bucks.
383cam
Sep 9, 2015 06:01 AM
punkmaster98
Sep 8, 2015 09:45 PM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
