[CA] WTB T/V accelarator cable
Old Dec 3, 2011 | 05:52 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
i found the part no longer need it
Last edited by DiabloWS6; Dec 13, 2011 at 08:27 PM. Reason: no longer need the part
Old Dec 3, 2011 | 07:01 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: WTB T/V accelarator cable
89-92 tpi throttle cables are wrap around style. are you needing a throttle cable and throttle valve cable ? gm 10163822
Old Dec 4, 2011 | 03:45 AM
DiabloWS6's Avatar
yeah i think your right on the wrap around style i dont know on both but i have seen it its just the single cable that wraps around if im right and has a wierd little notch at the end that would hook up on the throttle body the same cable then goes thru the firewall and slips on the gas pedal
Old Dec 11, 2011 | 10:47 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
I have a throttle cable from my 86 IROC. It is in perfect condition.
It wraps around the bracket on the TB and hooks into the hole on the one side of it.
$25.00 shipped for you
Old Dec 11, 2011 | 02:55 PM
DiabloWS6's Avatar
sorry but my car is an '86 i have the stock one and unless its the '88 & up style it wont work
Old Dec 11, 2011 | 04:41 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Here is another idea, get two '89-'92 throttle body gaskets and you can use the '86.
It will open enough area to supply air to the IAC (same as notching the bores)
Old Dec 11, 2011 | 04:55 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I didn't think of that one. Nice
Old Dec 11, 2011 | 05:31 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
http://www.tvmadeez.com/ If you haven't found the solution you want to go with, this site may have what you need........
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
