WTB Clutch Master Cylinder
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I need a master cylinder and the U bolt as well. Must be in working order.
Thanks!
Thanks!
Car: 1992 Pontiac Firebird
Engine: 454 BBC
Transmission: TH400
Re: WTB Clutch Master Cylinder
I may end up with an extra if you are in no big hurry. It wouldn't be until late Jan-February.
PM or email me in a few weeks to see if I have done the swap by then.
Car: 89 IROC-Z
I need one really soon here.
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I have one. Cant rember if it ahs the U bolt though
http://www.brucesthirdgenparts.com/s...d-Hydro/Detail
I am open to offers
I am open to offers
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
well that sux i just scrapped one of these, i had the whole freaking setup with slave and all
and it was still full of fluid and everything
at least im pretty sure i alreasy trashed it, ill double check though!
i tried and tried to find a new good home for it all and no one was interested at all and the parts all looked brand new,
good luck
good luck
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
If you already had the reservoir and hard plastic line, for around $35 a piece you can buy the master and slave from Autozone with a lifetime warranty and the slave body is made out of cast aluminium,the master body is either steel or aluminiun as well.
Pretty good deal I thought.
88SS6SPEED
Nov 11, 2015 07:05 AM
codeysabatini
Nov 10, 2015 04:07 PM
camaro1185
Oct 26, 2015 06:51 AM
