Looking for a hydraulic roller camshaft
Old Jan 4, 2012 | 12:10 PM
Badrs2810's Avatar
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
Looking for a hydraulic roller cam:
COMP Cams 08-305-8 276 HR-14*XTREME ENERGY Hydraulic Roller Camshaft
Or something really close, thanks
Old Jan 4, 2012 | 12:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Looking for a hydraulic roller camshaft
Mines abit bigger...was turbo cam but could work in anything with heads with good exhaust port/good exhaust system
292/292 233/233 .564/.564 with 1.6's and 112 lsa
Old Jan 4, 2012 | 02:12 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Thank you, but that's a little too big. I'm not wanting to go over .510. Which, when I add my rr it will slightly.
Old Jan 4, 2012 | 02:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Check camaroz28.com as well, as that cam is very popular in the LT1 world...may find one there. I have in the past.
LT4 hotcam 219/228 .492 with 1.5's
http://www.camaroz28.com/forums/part...inside-846314/
http://www.camaroz28.com/forums/part...am-ect-842286/
maybe some others around
Old Jan 4, 2012 | 04:09 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
I will, didnt even think bout that, thanks
Old Jan 4, 2012 | 05:35 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I have one i'm not using currently and is out of the motor.
Edit: it's a 7-503-8 not 8-503-8, CS-XR276HR-12 (its a 112 LSA instead of the 114)
This is the LT1 version but the only difference is the pin is longer. I trimmed it so it works in an 87' up roller block.
It is used but in great shape.
224/230 (276/281 @0.006)
0.503/0.510
uses Comp 986 springs (which I also have out of the motor too)
Ran for about 5K miles with no troubles.
I have a 406 with a 236/242 HR now so this is just taking up space unless I find another project to put the 350 back in.
$150 for cam and dual springs.
I don't have the retainers etc, those went into the 406.
Last edited by JP86SS; Jan 4, 2012 at 05:49 PM. Reason: Cam number is 7-503-8, not 8-503-8
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
