Need serpentine smog delete pulley
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Need serpentine smog delete pulley
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
you can get gm 10129569, but the export delete 10186167 is no longer available. a http://www.summitracing.com/parts/NAL-10129569/ gates part number 38024 is the same pulley used on the export delete it may fit on the 10129569.
Engine: Lb9
Transmission: M20
I been running like that for 10 years now, no problems ..... Dont use dayco belts, they seemed to stretch on that set up. I switched to a Gates about 5 years ago, its still on there. Granted I only put about 3,000 or 4,000 miles a year on mine.
So is there any advantage in using the export delete pulley over the one from summit? The summit one is a lot less than the originals I have seen on ebay and is a GM product but is the earlier version with the plastic pulley better?
Engine: Lb9
Transmission: M20
the export delete used the stock size belt, the 10129569 was used on the 12497697 setup with a shorter belt. Not really needed but insurance and helps with belt deflection.
