[SK] 2 tranny pan bolts for 91/92 Fbody 700R4
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
My yellow 92 GTA has 2 missing or broken off transmission pan bolts. I have tried buying new ones at a GM dealer but they aren't correct. They should be approximately 1 inch in length and a 1/2 socket would be used to remove them. They should also have a washer and the head of the bolt should say "M" on it as well as 5.8. I don't know for sure but it might be the same on 87-92 transmissions. It is the same bolt on my 91 and 92 GTAs. Below are some pics:
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: 2 tranny pan bolts for 91/92 Fbody 700R4
I don't have a pair but those should be easy to find from someone that has an aftermarket shifter. You have to replace two of the factory pan bolts with two pan bolts provided to complete the shifter installation.
Thornburg
Aug 25, 2015 01:46 AM
