Wanted: TPI Accessories
Subscribe
Mar 8, 2012 | 10:38 AM
Needed for swap: ignition system incl distributor, throttle body, brackets, thermostat housing, pcv lines & fittings, oil filler cap, fuel lines, etc.
Putting together a 383 with Edelbrock intake base and modified upper intake/runners. Have the fuel rails, injectors, & regulator, & that's about it. ECM & all sensors still attached to the car, I think it's all there.
Reply 0
Mar 8, 2012 | 02:55 PM
Re: Wanted: TPI Accessories
What year throttle body do you need. I have 2 of the earlier ones. Also have an adjustable fpr.
Reply 0
Mar 8, 2012 | 03:06 PM
I have a couple of thermostat housings, an air intake, fuel line bracket, tons of OE fasteners, and possibly a PCV line or two. Which brackets are you looking for exactly? Are you going to run a serpentine setup?
Reply 0
Mar 8, 2012 | 03:22 PM
I have an extra IAC housing if you're intersted. Asking $10 shipped.
Eldon
Reply 0
Mar 8, 2012 | 03:39 PM
Have a nice clean and solid used OEM distributor . Small cap for remote coil if that's the one you're looking for. PM or email me your email address for pics and other info if interested
Henry
Reply 0
Mar 8, 2012 | 04:51 PM
Let me get home and take stock of things, I'll get back to all of you.
Reply 0
Mar 9, 2012 | 10:07 PM
1992. Have an AFPR.
Reply 0
Mar 9, 2012 | 10:10 PM
Quote: I have a couple of thermostat housings, an air intake, fuel line bracket, tons of OE fasteners, and possibly a PCV line or two. Which brackets are you looking for exactly? Are you going to run a serpentine setup?
Need a clean t-stat housing, throttle cable bracket, can't tell what else yet as the engine is at the builder's and the car is at the cleaners. Have all the serp brackets I need, going to customize something with alternator and PS pump only, no smog or AC.
Reply 0
Quote: I have an extra IAC housing if you're intersted. Asking $10 shipped.
Eldon
Will need that I think. Incl IAC motor?
Reply 0
Mar 10, 2012 | 01:08 PM
Quote: Will need that I think. Incl IAC motor?
PM Sent. Oh, and I totally forgot that I have a nearly brand new coil and O2 sensor. They were on the car for about 500 miles, if that.
Reply 0
Mar 16, 2012 | 05:32 PM
Did you get the distributor pics OK ?
Reply 0
Mar 20, 2012 | 09:34 PM
Thanks to all who've sent pics. I'm trying to pin down one local guy that says he has some stuff before I ask you guys to send me stuff from all over the US. Thanks for your patience, I should be able to let you know within a couple of days.
Reply 0
Mar 25, 2012 | 03:47 PM
I have a Edlebrock/BBK Throttle body 52mm...200.00 plus shipping email me at irocz86350@hotmail.com if your interested. Thanks Kenny
Reply 0
Subscribe
