In need of motor brackets and bolts
Old Apr 8, 2012 | 11:24 PM
philly5eagle's Avatar
I'm helping my son rebuild his 91 305 tpi. When we bought it the motor was torn apart and a few parts were missing.
I'm looking for the pass side accessory bracket. It holds the a/c comp and the air pump.
Also need the two small brackets that attach the accessory brackets to the manifolds (one on each side of the motor) including the bolts.
I need the crank pulley, waterpump pulley (including bolts), and the belt tensioner.
I also need the bolts and studs that attach both of the accessory brackets to the block.
I need the flex plate to block bolts.
Old Apr 9, 2012 | 08:30 PM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
Re: In need of motor brackets and bolts
i can help with all of the parts needed
passanger accessory bracket,
both support brackets with bolts
crank pulley
water pump pully with bolts
all bolts and sutds with nuts to moulnt both accessory bracket to the block,
i need to take the trans out but i can get you the flex plate bolts also
Old Apr 10, 2012 | 09:35 AM
crank pulley
That is great. My son is 18 and having a hard time with finding some things. How much for each and how much to ship it all to zip 23452? You dont have to worry about the flex plate bolts if you have to pull the tranny. I don't want to create extra work for you. I may also be interested in the tensioner if you have it.
Christian
Old Apr 10, 2012 | 07:24 PM
Transmission: auto
philly5eagle, can you pm me with your e-mail address
Old Apr 10, 2012 | 10:37 PM
Ted, pm sent
Old Apr 11, 2012 | 04:28 AM
Transmission: auto
philly5eagle, pm replyed to an e-mail sent, if i missed anything just add it to the e-mail and i do the the tensioner also, as far as the flywheel bolts go thats not a problem i need to pull the engine this weekend its sold and the trans has to come out anyway,
Old Apr 21, 2012 | 08:32 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
flexplate to block?
wtf?
i have tons of SBC engine bolts and stuff none is specifially TPI
but if any are same as carb, or as TBI or as 1996-up SFI style engine then i could help
email or text or hit me up username fastr68 on yahoo IM anytime
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Elliswon
Aug 10, 2015 12:33 PM
