V6 Smog Pump Delete Bracket W/ Pulley
Old Jul 28, 2012 | 05:23 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
Would like to know if anyone has a V6 air delete pulley set-up in working order, and not bent? Possibly with bolts.
Old Jul 30, 2012 | 02:41 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: V6 Smog Pump Delete Bracket W/ Pulley
The serpentine V6 was offered without a smog pump. Just remove the pump and get the proper belt and you should be G-T-G ! Here's a pic of my old 87 V6......
If You really want the 2.8 Smog Delete Pulley let me know - I think I've still got one around here somewhere.
Old Jul 30, 2012 | 03:01 PM
Axle/Gears: 10 Bolt
Moderators can close the thread. I bought one on ebay yesterday. I have the belt set-up in that fashion and it is the stock set-up. I have a new tensioner, A/C compressor, and belt but right below the alternator and above the crank the belt wobbles and vibrates so much when the A/C is on. Sometimes when I first start it w/o the A/C on it does it for a couple of seconds. I just believe the Idler pulley should of been there from the start. I don't know how people with working A/C units deal with the vibration and noise.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
jaridjohn
Oct 5, 2015 07:01 AM
evilstuie
Sep 24, 2015 02:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
