[TX] Need (special) TPI Runner Bolt For 1988 Formula 350 Firebi
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Sunday, I replaced my injectors with some reman Bosch IIIs. In the process I managed to drop the rear most drivers side runner bolt somewhere between the upper bell housing and firewall. Tried to fish it out with a magnet, but so far no luck. Naturally, it was the one special bolt of the lot, a hex head with a rod sticking out, helps keep some of the throttle cables from rubbing on the runner. Any one got a spare they could sell me?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need (special) TPI Runner Bolt For 1988 Formula 350 Firebi
Engine: 5.7L TPI
Thanks, but that one is different from the one I have (had). It's not the center but the rear most runner bolt. It just has a smooth rod about 1/16" thick by 1-1/2" long sticking out of the bolt head.
Engine: Lb9
Transmission: M20
The hardware on the tpi is metric 8mm
Engine: 5.7L TPI
I took some photos of the TPI before disassemble. I'll check and see if that bolt is visible in any of them. BTW, mine doesn't have have the bolt with the cable guides like the one in your photo.
Thanks for the exploded diagram.
Engine: 5.7L TPI
Can't see it well in my photos, but I found a pix of it on line.
Engine: Lb9
Transmission: M20
that is the stud missing the 8917256
It does not go in the back of the runner.
http://www.ebay.com/itm/Genuine-GM-0...ab97f2&vxp=mtr
It does not go in the back of the runner.http://www.ebay.com/itm/Genuine-GM-0...ab97f2&vxp=mtr
Engine: 5.7L TPI
Hummm....., well that's were it was when I took it out. That photo is a 1988 'vette TPI bolt set, where would the bolt normally go?
Engine: Lb9
Transmission: M20
Engine: 5.7L TPI
Sanjay
Aug 12, 2015 03:41 PM
