83 ta isolation relay
Old Dec 13, 2012 | 07:04 PM
kitt23's Avatar
need the headlight isolation relay for a 83 ta. must be good!
Old Dec 26, 2012 | 08:56 AM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
Re: 83 ta isolation relay
What is that? The headlight relay or the headlight actuator relay? Either way Rock Auto has them both for under $20...
http://www.rockauto.com/catalog/rafr...&parttype=3400
http://www.rockauto.com/catalog/rafr...&parttype=3420
Old Dec 26, 2012 | 09:33 AM
kitt23's Avatar
ISO relay is different it a special Kind of relay for headlamp motors. They don't make it new
Old Dec 26, 2012 | 10:11 AM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
This may help...
GM dealers show that 10022620 relays are discontinued and 10031018 relays are a replacement for all the relays. As far as I can tell, 10031018 is a replacement for 10031246 Actuator Relay, but cannot be used for the 10022620 isolation relay. I do not believe there is a replacement made for 10022620 and I notified GM about this possibly being wrong in their parts catalog. GM sells 10031018 for $50 and I did not want to spend the money to find out.
Car Quest sells a replacement for 10031246 for around $22. The part number is 56-1793. The only replacement 10022620 I could find is on other Firebirds and Fieros around the same years. Just look for the 10022620.
Found in this thread...
https://www.thirdgen.org/forums/elec...headlight.html
Old Dec 26, 2012 | 10:54 AM
kitt23's Avatar
Yes i seen that site before thank you! Gotta bitdfisomeone parting a early thirdgen
Old Nov 24, 2013 | 07:04 AM
kitt23's Avatar
bump still need 1
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
