[KY] Complete TPI
Car: 99 HOSS 6 Speed
Complete TPI
Looking for a complete TPI, dis. cover, goose neck, fuel rails, the only thing that I really do not need is the injectors. Must be in good shape. No dents on the runners. Must also be 87 up model.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Complete TPI
I've got most of the MAF 87 TPI parts,....
The runners are in pretty good shape but there are a few dings in them. The Intake was blasted re-painted, got a good cold start injector, fuel rail, air cleaner, ect.......
Send me a PM with your ZIP code if your interested and need additional info.
Re: Complete TPI
Thanx for trying Jason,..... but those lenses are NOT the same as the picture that I sent to you. If you do find the correct lenses I'm looking for, feel free to let me know.
Re: Complete TPI
i have a tpi manifold from my 89 iroc z 5.7l. everything included upper and lower plenum, runners, plenum extension, fuel rails, injectors, bbk adjustable fuel pressure regulator, throttle body, air foil, ecm, 2 wiring harness' (cut up but can make one complete from the 2), distributor, msd coil (gm style), mass air flow sensor, thermostat housing, fuel lines and possibly intake ducting and filter housing with k&n filters.
looking to get about tree fitty ($350)
Car: Camaro
Transmission: 6 Speed
Axle/Gears: 9 bolt 370
Re: Complete TPI
Terrell351
Jun 13, 2021 01:13 PM
Sanjay
Aug 12, 2015 03:41 PM
