In Need Of Intermediate Lower Steering Shaft
Transmission: Manual
Hello Third Gens,
I'm in need of a Intermediate Lower Steering Shaft in good working order. I found a new one on the classic industries website for $150 + Shipping but I can't afford that. I was hoping to get a used one for around $50. Please send me a PM if you can help.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: In Need Of Intermediate Lower Steering Shaft
A worthwhile upgrade...... https://www.thirdgen.org/forums/engi...t-upgrade.html
Car: Camaro
Transmission: 6 Speed
Axle/Gears: 9 bolt 370
Hello Third Gens,
http://www.facebook.com/ThisWeekInCamaro
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I ahve one also
http://www.brucesthirdgenparts.com/s...teering/Detail
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
GO to the local junk yard and find a 1997 astro mini van the shaft will be incased in a rubber boot , take the shaft AND bearing , you will have to turn the end by the steering column 90 degrees then install the astro bearing in place of the nylon bushing in the end of the column . the shaft will fit rite on both sides . you will have to grind out the spot on the column shaft to allow the bolt to clear you can buy the whole thing for $10 (shaft and bearing) if you are not very mechanical and cant change a u-joint or are confused by what i've said , buy one that people are selling . pre modified bolt on . but make sure you tell them you want the astro shaft .make sure its been modified and try to get the bearing ,thats optional but makes a big difference. good luck.
morrow
Jan 13, 2024 12:29 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
Night rider327
Sep 2, 2015 04:17 AM
