WTB: 90-92 L98 pistons+rods
Old Feb 3, 2013 | 08:37 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Hey folks,
is there any chance one of you guys have a set of connecting rods and flat-top pistons out of the 90 / 91 / 92 L98 kicking around that you would like to transform into cash?
please let me know!
thanks
Old Feb 13, 2013 | 11:46 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: WTB: 90-92 L98 pistons+rods
Originally Posted by ownor
Hey folks,
please let me know!
thanks
I have 6, possibly 7! Not a complete set though.
it is my understanding that the LT1 stuff is the same piston, but with better rods. That might be an option for you as well.
Old Feb 13, 2013 | 12:00 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Are 90-92 pistons and rods different then 87-89?
And yeah, the LT1 powdered metal rods are supposed to be better, and pretty cheap.
Old Feb 13, 2013 | 06:14 PM
The (90?) 91-92 pistons are flat top 4 valve relief.
IIRC the older ones have a slight dish to them.
Yea I know the PM rods are better, had them in a crate motor I beat the living hell out of with nitrous to boot. I am just not sure if all year LTx's got them or just the later years, I know my buddy's 97 LT1 Z had them.
Old Feb 13, 2013 | 07:35 PM
Twin_Turbo's Avatar
90-92 pistons
Old Feb 14, 2013 | 09:24 AM
Car: 1971 Camaro
Engine: 427
I'm curious why the op wants these, as apposed to a replacement hypreutectic.
I have had a hard time finding a 350 block that can stay standard bore letely anyway.
Old Feb 14, 2013 | 10:25 AM
My block was the original 91 block, never had any work done to it, they had to go .030 over to line up the center of the bore with the crank (according to my machine shop.)
Old Feb 17, 2013 | 05:16 AM
ownor's Avatar
Engine: LS1 / L03
Will sounds like you had what they call a bore shift, where the bores are not (well not perfectly FWIW) aligned with the crank centerline.
for the other comments, as TT already indicated these are the 90-92 pistons with a smaller dish (imho results in 9.5 vs. 9.3:1 with the 64cc heads)
anyways, i'm now actually looking for a whole 94-up LT1 rotating assembly since from what i gather these are lighter, stronger and boost CR, which is exactly what i'm looking for. i don't intend to get the block bored, and stock stuff should suffice my power goals and fits the bill, literally.
i'm looking at buying a local one but will come back if i dont find one
thanks!
Old Feb 18, 2013 | 01:10 AM
thanks!
Bore shift, that is pretty interesting.
IIRC the LT1 rotating assembly is same exact piston as 90-92. Better PM rod and a Nodular Steel crank VS the nodular Iron in the 3rd gen Steel being lighter and stronger. if you still run a stock L98 head (64CC Chamber) you will not go up in CR. The LT1 heads have 58cc chamber that is why they have the 10.4:1 cr
Old Feb 18, 2013 | 03:24 AM
ownor's Avatar
Engine: LS1 / L03
Not sure if it was referred to as core shift or bore shift, but it's about little alignment flaws in the casting process which are no problem for a standard road mill, but might be worth straighting out for HiPo builds.
for the LT1 rotating assy, from what i've read the early LT1 pistons are the same as the late L98, same for the 'pink' rods. The PM rod was introduced in early 94 and was standard from 95 onwards, the pistons were changed to an updated hypereutectic piston with thinner rings imho. Piston tops are about the same cc-wise. Imho just the LT4 used the nodular iron crank, but the standard LT1 crank should be lighter than the L98 crank still. Plus it's (supposedly quite nicely) balanced for the lighter rods and pistons.
The LT1 heads have 54cc btw
Old Feb 18, 2013 | 06:01 AM
Car: 1971 Camaro
Engine: 427
Have you measured your bore, to see if it can stay standard?
Old Feb 18, 2013 | 06:52 AM
ownor's Avatar
Engine: LS1 / L03
Frankly i need to admit i haven't, but would have expected it to be okay since i can still see a nice crosshatch and the top ridges are not bad either.. Oh well what do i know
Old Feb 18, 2013 | 09:52 AM
I thought LT4 heads were 54cc LT1's were 58cc...Oh well My LTx knowledge is minimal cause I don't care for the engine.
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
hartsmike
Oct 4, 2015 01:00 PM
