[BC] Need TCC brake switch w/cruise for 1987 IROC 700R4
Old Jul 12, 2013 | 01:26 AM
Crusherfied's Avatar
Axle/Gears: 9 bolt disc 3.27
As the title says. Need the combo switch on the brake pedal that has a cruise control vacuum cutoff and the TCC power control to the trans. Should have a pink/black wire and a purple wire attached to it. Please quote price and shipping to V0E 1V1. Thanks.
Old Jul 12, 2013 | 06:33 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Re: Need TCC brake switch w/cruise for 1987 IROC 700R4
im parting out an 86 iroc with an auto trans. the brake pedal and assembly is still there will this work?
Old Jul 13, 2013 | 02:51 AM
I can't see why not. Does your car have cruise control? I believe the switch is integrated with the C.C. brake cutout switch. Since my car has cruise I will need the appropriate switch.
It is also possible that this particular part was also used on many other Chev cars as well, but I can't confirm that, a local auto wrecker suggested that as a possiblility.
If you take off the panel above the pedals, you should be able to squeeze underneath and have a look up at the brake pedal, a light of somekind will likely be handy. There should be TWO switch assy on the brake pedal. The one I mentioned, and the other controls the brake lights. The one I mentioned will have a thick black vacuum type line attached to it, this line goes through the firewall and is for disengaging cruise control when the brake pedal is applied.
Old Jul 13, 2013 | 08:06 PM
tonys91rs's Avatar
Car: 91 Camaro RS
the car has cruise control and an automatic. I know the cruise was intact and the brake pedal is still in it. the steering column is out and the dash panels. I will get a better look at it on sunday and remove the described item and send you out a picture. im pretty sure its there. all yours if its there. ill get a shipping quote as well
Old Jul 14, 2013 | 02:37 PM
Thanks for looking, but I found one yesterday at a local wrecking yard.
jklein337
Sep 19, 2018 06:23 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
TA8487
Aug 16, 2015 12:21 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
