[KY] WTB Lower Firewall AC Box and Metal Coolant Line
Old Nov 3, 2013 | 10:50 PM
cowansauto's Avatar
I am looking for a crack free lower AC box that the evaporator sits in and the metal coolant line that goes under the AC box along the fender rail towards the radiator.
Attached Thumbnails WTB Lower Firewall AC Box and Metal Coolant Line-image.jpg
Old Nov 7, 2013 | 05:45 PM
'86 Sport Coupe's Avatar
Car: 1986 Camaro Sport Coupe (Part Out)
Engine: 2.8 MPFI V6
Transmission: 700R4 Automatic 4 speed
Axle/Gears: 3.42 Open With Drum Brakes
Re: WTB Lower Firewall AC Box and Metal Coolant Line
I think I might have the lower AC box you need. Not sure if I have the same pipe you have as what I have is out of a V6 car. Let me know if I have anything you are interested in.
Attached Thumbnails WTB Lower Firewall AC Box and Metal Coolant Line-sport-coupe-engine-10
Old Nov 10, 2013 | 08:07 PM
cowansauto's Avatar
I couldn't tell by your picture. It's the one that runs under the box. Check your box and let me know it's consition
Old Nov 10, 2013 | 11:26 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got an AC box - but it's got a busted mounting tab.
I'll take a look for the coolant pipe tomorrow and will post an update here.
Old Nov 11, 2013 | 12:30 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I have a good condition one PM me if inteerested
Old Nov 12, 2013 | 09:15 AM
Engine: 2.8 MPFI V6
I wouldn't expect anything too crazy as it's still in the car. I'll give it a look and let you know.
Old Nov 12, 2013 | 05:13 PM
John in RI's Avatar
When I put an LT1 in my car I used factory Cooling lines from a V6 Thirdsgen so both pipes ran past the headers on the pass frame rail. I just cut them to fit and clamped hoses on. I'm not sure how your cooling system is set-up, but figured it was worth pointing out.
I found the stock coolant Pipe for AC in factory finish (like you have now),... and have a V6 style pipes that were blasted and re-painted.
The AC Box is $25 and the Pipe is $25. ( either the stock V8 pipe or the blasted V6 pipe). Shipping not included; Post your ZIP code if your interested.
Dialed_In
Aug 20, 2015 01:45 PM
TA8487
Aug 16, 2015 12:21 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
