[IN] speedo gear housing and clip
Old Nov 20, 2013 | 10:46 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I need the plastic or metal housing thay sits in the tail shaft that holds the speedo drive gear for a mechaical speedo. My old housing was for an electronic so my current housing won't work. I also need the retaining ring and bolt as well.
Old Nov 21, 2013 | 09:40 AM
Engine: L31 350
Re: speedo gear housing and clip
Bumb
Old Nov 25, 2013 | 05:52 PM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
Is this what you are looking for? This is the larger housing, for 40-45 tooth. I also have the smaller one, for 39 and less teeth. Gear not included. From an '86 Camaro. With clip and screw.
Jeremys87
Jul 14, 2022 09:08 PM
Orr89RocZ
Oct 7, 2015 12:47 PM
GTAman
Aug 27, 2015 10:29 PM
madsv1000
Aug 20, 2015 06:45 AM
