Injectors wanted
Old Jan 4, 2014 | 08:46 PM
sparks454's Avatar
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
Injectors wanted
Looking for a good tested set of 8, 68lb or 72lb injectors. Let me know what you have..Also, wholesalepartsbarn on ebay carries tons of refurb'd injector sets from TLF performance. Free shipping and $200 with a 1 year warranty doesn't sound bad at all for a set of 68lbs or 70's, but has anyone ever used injectors from them? Flow matched as well. Ford or GM ev1's, high impedance..Thanks, Chris. c_lehman67@hotmail.com
http://www.tlfperformanceparts.com/
Remanufactured by TLF Performance Parts, USA
Colors may vary
Set of 8
Warranty: 1 year
TLF Performance Part fuel injectors for the Camaro & Corvette feature drop-in fitments for a simple installation. Since they are made from Bosch manufactured injectors, they will fit directly into the stock or any aftermarket fuel rail.
ALL FUEL INJECTORS ARE FLOW MATCHED & FLOW TESTED.
http://www.ebay.com/itm/380806888522...ht_1003wt_1026
http://www.ebay.com/itm/380807834033...ht_1122wt_1026
Old Jan 7, 2014 | 09:23 PM
southbay08's Avatar
Re: Injectors wanted
Those injectors are actually modified Bosch lll's. Bosch does not make that type of injector in 70lb. If you want to give us a call we can try to help you as well.
Old Jan 7, 2014 | 09:25 PM
sparks454's Avatar
Car: 1987 GTA
I will check out your products or Let me know what you have around 68 or 72 then for under $199. I think I will give them a try since they have a 1 year warranty on them. I also work for Siemens so I have had companies grant me a 15% discount, but some of those are pricey. PM me with what you have, but for the price and flow ratings, I think the ones offered by TLF are decent.
Thanks,
Chris
Old Jan 8, 2014 | 05:34 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
68 or 72 lbs?
For the procharged t/a ??
-- Joe
Old Jan 8, 2014 | 06:29 AM
sparks454's Avatar
Car: 1987 GTA
Actually for a different car that I am working on, but I am looking for a set for mine as well. Was going to change mine in the spring if I can't get it tuned with the 30's in there.
Old Jan 8, 2014 | 07:39 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ahh. 30's should support 490-500hp depending on the bsfc of the total setup.
I'm tempted to sell my 42s and move to a 50lb for my turbo build.
-- Joe
Old Jan 9, 2014 | 07:19 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You alive? I sent you a PM yesterday...
--Joe
Old Jan 9, 2014 | 07:34 AM
southbay08's Avatar
Yes I'm alive..wasn't in front of my computer yesterday. Dealing with some major heating issues with the plumber. I will look at your pm now
Old Jan 9, 2014 | 08:22 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
My water pipes froze at my house. Hopefully this weekend will thaw out.
Global warming my ***
-- Joe
Steve78LT
Feb 24, 2016 12:15 AM
gta90
Sep 15, 2015 04:00 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
tmellott89
Aug 16, 2015 02:58 PM
