xe-276hr - Vortec Intake - Roller Rockers
Old Jan 8, 2014 | 10:47 AM
Jose Zuñiga's Avatar
Hi all,
I'm looking for a xr-276hr cam (can be the cc503) or a similar cam, also a good vortec intake high rise for carb and a roller rockers 1.6 self-aligning
Old Jan 8, 2014 | 08:28 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: xe-276hr - Vortec Intake - Roller Rockers
I have a complete set of GM bowtie 1.6 ,self aligning roller rockers from my Lt1 that i am not using.
Will sell for 150.00
Old Jan 8, 2014 | 08:35 PM
Dude, I purchased a roller rockers a few minutes ago
Thank you so much.
I still looking the cam and the intake.
Old Jan 8, 2014 | 09:07 PM
Car: '88 Trans Am
Engine: 5.7L TPI
Oh good deal, you got a set.
Old Apr 5, 2015 | 07:40 PM
doppler's Avatar
Comp Cams $275 new - This cam has very few miles on it. I want $150 for it.
Tim 918-527-5316
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,900-5,600
Intake Duration at 050 inch Lift: 227
Exhaust Duration at 050 inch Lift: 241
Duration at 050 inch Lift: 227 int./241 exh.
Advertised Intake Duration: 283
Advertised Exhaust Duration: 303
Advertised Duration: 283 int./303 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.513 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.498 in.
Valve Lift with Factory Rocker Arm Ratio: 0.513 int./0.498 exh.
Lobe Separation (degrees): 107
Camshaft Gear Attachment: 3-bolt
Computer-Controlled Compatible: No
Grind Number: 283THR7
midge54
Dec 27, 2019 04:14 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
