9 Bolt spider gears
Old Jun 22, 2014 | 01:46 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
9 Bolt spider gears
Got mine apart and found the cross shaft was broken. What have you?
Old Jun 22, 2014 | 09:20 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 9 Bolt spider gears
Isn't the 10 bolt and 9 bolt cross shaft the same ??
I've got a used 3 series carrier,.... Had 3.45's on it. ( Gears are gone ) cones almost certainly need to be replaced. If your intrested just get back to me with a realistic offer for it and be sure to include your ZIP code for a shipping quote.
Old Jun 22, 2014 | 11:48 PM
Car: 1990 Camaro RS
Engine: L31
No, the 10 bolts ride on a cross shaft that is removed to push the axles in to pull the C clips. I may just part this one out to finance another rear, it is a 3.27 geared unit.
hectre13
Dec 11, 2023 08:14 AM
junkcltr
Aug 2, 2019 11:12 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
