Need parts bellhousing and TPI
Old Oct 4, 2014 | 09:19 PM
bbc632's Avatar
Car: 1990 z
Engine: 383 small block chevy
Transmission: tko 600
Axle/Gears: strange dana 60 4:10
Needing a lakewood bellhousing 15020 and a camaro TPI from the intake up. Do not the harness THANKS.
Old Oct 6, 2014 | 08:19 AM
the973camaroguy's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 2.77
Re: Need parts bellhousing and TPI
i have a tpi intake where are you located
Old Oct 6, 2014 | 11:09 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I have some TPI parts as well if you need them. Was going to use them on another engine that I was building, but that engine has been sold awhile back. It's not complete though, just the lower intake, runners, plenum, throttle body (less the IAC housing), waterneck, and distributor. You would need the fuel rail, regulator, injectors and IAC housing...
- Rob
Old Oct 6, 2014 | 06:40 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got the TPI;
https://www.thirdgen.org/forums/engi...injection.html
Edit: Small parts too.......
Caspar
Jun 19, 2016 11:19 PM
masonta
Aug 31, 2015 10:14 PM
383backinblack
Aug 15, 2015 06:36 PM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
