350 tbi chip or ecu
Old Feb 24, 2015 | 10:55 PM
sorrys70's Avatar
350 tbi chip or ecu
i did a 350 tbi swap and am looking for the 350 auto chip preferably with the governor removed. there seem to be none left on ebay or in the junkyard -thanks
Old Feb 24, 2015 | 11:28 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
Re: 350 tbi chip or ecu
What year engine what car did it come out of?
Old Feb 24, 2015 | 11:51 PM
sorrys70's Avatar
its from A 71 monte carlo but its been rebuilt. its .30 over with a mild cam
Old Feb 24, 2015 | 11:54 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
If its the original engine from the monte I doubt it came with a computer in 71...do you have the numbers from thr block
Old Feb 25, 2015 | 11:22 AM
sorrys70's Avatar
No, i put the monte engine in the car and put the tbi from the old 305 on it. Im looking for a 350 chip so it doesn't run way too lean.
Old Feb 25, 2015 | 11:24 AM
sorrys70's Avatar
I dont remember the numbers but it shouldn't matter because its not a stock 71 engine
Old Feb 25, 2015 | 03:22 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
Alright so what year was the tbi stuff you used
Old Feb 25, 2015 | 03:31 PM
sorrys70's Avatar
1991 rs auto 305
Old Feb 25, 2015 | 03:37 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
Im pretty sure any gm pickup around the same year would have the prom you need...if I can find one ill post
Old Feb 25, 2015 | 07:19 PM
sorrys70's Avatar
I was under the impression you cant use the truck ecm in a thirdgen
Old Feb 25, 2015 | 07:21 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
Yeah thats why I was only looking for a prom from a 350 tbi you should jus get your stock chip reprogrammed
Old Feb 25, 2015 | 07:27 PM
sorrys70's Avatar
i would love to but i cant afford a 200$ chip right now i was hoping to find a old cop car ecu or chip for a better deal.
Old Feb 25, 2015 | 07:29 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
Yup well good luck with it if I can find one ill hit you up?
Old Feb 25, 2015 | 07:38 PM
sorrys70's Avatar
thank you. im thinking a carb may be in my future.
Old Feb 25, 2015 | 07:39 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
Probably easier lol
Old Feb 25, 2015 | 09:11 PM
whyt86roc's Avatar
Car: 92 Camaro RS
Engine: 355 L98 Carb
Transmission: WC T5
Axle/Gears: 3.73 Auburn Posi
I've got a ECU from a 1992 Caprice with the 350 TBI engine/ auto transmission if you are interested. The Service No. is 16136965 AYDP Prom.. I looked it up a couple years ago and the new GM PN is 88999162. I was gonna use it when I changed my 92 RS over to a 350 engine but never did..
I went to newgmparts.com and ran the new GM PN and it came up with 91-93 Caprice cars with either the 5.0 or 5.7 engines. Even had a couple of the 4.3s listed.
I'll take 20 dollars shipped if you want it
xkingcodex
Feb 12, 2020 07:43 PM
italiano67
Dec 11, 2016 09:21 AM
Dwayne614
Sep 28, 2015 08:33 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
