V-belt setup
Old Jun 17, 2015 | 03:03 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
V-belt setup
Anyone have a factory v-belt setup? I need everything to swap over, so the more you have, the better.
I dont have A/C or a smog pump, so I just need the brackets for the power steering and alternator, pulleys, and maybe the water pump and bolts would be nice.
Surely someone has this laying around?
Old Jun 17, 2015 | 04:16 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: V-belt setup
I have 2 full V belt pulley/bracket setups. 1 from a '84 LG4 and 1 from an '87 LG4
Old Jun 17, 2015 | 04:42 AM
Car: 1988 Camaro
Re: V-belt setup
Here are some pictures. I'm in Bowdon, GA. so depending on shipping (water pump is heavy) you might come out cheaper to ride up here and pick them up, but I can and will ship.
'87 LG4 flat syle ribbed V belt
I have the belts laying around for it as well
'84 LG4
I have the engine removed and parts pulled off, just didn't have a picture of pulleys and brackets.
I do not have a power steering pulley puller so I can not remove the pulley and bracket from the PS pump at this time.
I will take $125 + shipping for everything though.. That's that $15 each for the pulleys, brackets, pumps
PS pump/bracket/pulley (no pressure hose), Alt pulley and bracket (alt not included), water pump and pulley, crank pulley, and all of the bolts and any of the belts I find that I tossed to the side when I removed engine.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
