[CA] WTB Rear end for 87 IROC
Old Nov 21, 2016 | 11:10 AM
drewdown84's Avatar
Car: 1987 Camaro IROC
Engine: V8 5.0L TPI
Axle/Gears: 10 Bolt
==== UPDATE ===
Rear end has been located, thanks all!
Looking for a rear end for my 87 IROC.
A housing would be ok, but I prefer a posi/disc setup so I can just switch my damaged one out.
PM an let me know.
-Andrew
Old Nov 21, 2016 | 02:37 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: WTB Rear end for 87 IROC
Do you have a 10 bolt or a 9 bolt?
Old Nov 22, 2016 | 08:43 AM
drewdown84's Avatar
Engine: V8 5.0L TPI
Axle/Gears: 10 Bolt
Just checked the rear end and it is definitely a 10 bolt.
Old Nov 22, 2016 | 09:04 PM
dixie wrecked's Avatar
Car: 91 ws6
Engine: Carb'd 334 stroker
I have a 10 bolt one wheel wonder drum rear from a 92, complete less e-brake cables and drums. Granny geared. I won't have a use for it, $20+ shipping and it's yours. I'm in Kansas, though, I don't foresee shipping being cheap.
Old Nov 22, 2016 | 10:25 PM
Dyno Don's Avatar
I have a 10 bolt 3.42 posi disc rear but no brakes $250
I also have a 9 bolt 3.27 posi disc w/brakes (PBR's) new rotors and pads
but the E-brake cables are for a 4th gen it it would require a special bracket
to connect them $450
I can make the bracket
Old Nov 28, 2016 | 01:45 PM
drewdown84's Avatar
Engine: V8 5.0L TPI
Axle/Gears: 10 Bolt
dixie: thanks for the offer. I'll keep you in mind if I cannot find something local.
dyno don: does the 10 bolt have the axles and everything else needed? also is it tight and useable or would I have rebuild? I am definitely interested as I am located in North County San Diego.
Old Nov 28, 2016 | 03:22 PM
Dyno Don's Avatar
The 10 bolt 3.42 is complete less brakes.
It is ready to use.
Old Dec 1, 2016 | 11:02 AM
drewdown84's Avatar
Engine: V8 5.0L TPI
Axle/Gears: 10 Bolt
PM'ed you DynoDon with my number.
Old Dec 6, 2016 | 08:26 PM
92battlered's Avatar
Want a title? Post!
Hi I'm Carter,
I have a newly rebuilt 1991 Z28 rear end it's a high performance rear end 3.42 gear set BR eaton posi $400.00
You can call me at (480)747-0006 I'm in AZ
Old Dec 7, 2016 | 04:11 PM
drewdown84's Avatar
Engine: V8 5.0L TPI
Axle/Gears: 10 Bolt
Thanks 92, but I picked up the rear end locally from Dyno Don.
