MAP sensor and bracket
Old Dec 8, 2018 | 01:01 AM
GeneralDisorder's Avatar
Swapping to EBL. For my 86 Trans Am.
Thanks,
GD
Old Dec 12, 2018 | 06:17 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: MAP sensor and bracket
You're also looking for a TPI one, not the TBI one, is that correct?
Old Dec 12, 2018 | 07:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Doesn’t it mount on the bulkhead?
tpi 90-92 mounts on a bracket on a boss on the plenum.
Old Dec 12, 2018 | 07:27 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yes' the TBI one does. Just asking to make sure which one he wanted
I'm really lo tech. Not familiar with EBL
Old Dec 12, 2018 | 11:02 PM
Well I'm not really sure.... I will be going to the First intake.... not sure if that has the bosses. My current intake is the 86 TPI intake. I'm installing the EBL prior to the engine / First intake install so as not to make too many changes at one time..... From what I have read the TBI and TPI use the same sensor.... if there is a bracket that will mount to the 86 bulkhead that would probably be ideal.
GD
Old Dec 13, 2018 | 08:51 PM
Mike 92LX's Avatar
I have one from a 90 TPI car if you need it
mikeymorris3@yahoo.com
TPIMonteLS
Jun 23, 2012 06:12 PM
S10Wildside
Mar 17, 2010 01:19 PM
Birdstheword
Jan 3, 2010 05:35 PM
nightrider87
Jul 21, 2004 05:28 PM
