[CA] Wanted: 90-92 L98 TPI Harness unmolested
Re: Wanted: 90-92 L98 TPI Harness unmolested
You should try to pm this member, a lb9 auto harness is the same.
https://www.thirdgen.org/forums/member.php?u=152779
1 Post
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Camaro or Firebird? Battery location makes them different and I believe the fuel pump test connection is also in a different location. The 90 TPI harnesses are slightly different than 91-92.
maroon88iroc
Members Camaros
04-08-2018 07:54 PM
330hp_91RS
03-25-2003 07:54 PM
330hp_91RS
03-17-2003 10:56 AM
