[TX] A/C Compressor Brackets
Old Mar 12, 2019 | 11:47 PM
jamesv's Avatar
Car: 1987 Chevrolet IROC-Z Camaro
Engine: LB9 > L98 5.7-liter V-8 TPI
Transmission: MD8 4-Speed Automatic MX0
Axle/Gears: GU5 3.23 G92
I'm looking to purchase a set of air condition compressor brackets for an 87 Camaro with a 5.0 TPI engine. The compressor is mounted on the driver side and i believe the set includes around 7 or 8 pieces. I am also interested in purchasing the OEM hoses that bolt to the back of the compressor and even the compressor if it is still operable. The attached photograph is of the single bracket that is holding the compressor on my vehicle along with the aftermarket freon hoses. Thanks in advance!
James
Old Mar 13, 2019 | 03:56 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: A/C Compressor Brackets
I've got the TPI AC Lines and a few of the compressor brackets...... I do not have the compressor. I'll try to post a pic tomorrow.
Old Mar 13, 2019 | 08:24 PM
jamesv's Avatar
Thanks John, I appreciate it.
Old Mar 14, 2019 | 09:10 AM
firebirddude142's Avatar
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
James
I have all the parts you need. Pm or text me 6128602513
Old Mar 15, 2019 | 07:57 AM
John in RI's Avatar
James;
( You might know this already; but: ) If you look at the 2 pics below you will see that you are using ( at least) 1 of the AC brackets wrong right now. The one you have at the back/top of the compressor to hold it up should be mounted on the front of the compressor.
Here's a pic from last night:
I might have the rod type bracket(s?) too,..... but I've got no way right now to confirm what rod type bracket is the right length.
Haven't looked into shipping yet because I don't have a good box at the ready and might have to make 1; the box will be kinda' big due to the AC lines. I'll be on the lookout for a box this afternoon.
Old Mar 17, 2019 | 07:54 PM
jamesv's Avatar
John,
I found the correct brackets. I got them from the guy who I bought the car from and I thought I had found the correct lines but turns out they were incorrect. How much for the a/c lines you show in the photo?
Old Mar 21, 2019 | 02:53 PM
John in RI's Avatar
Package Shipped !
614Streets
Jul 16, 2003 08:50 PM
