Ecm
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Ecm
I have a new refurbished 1227165 for $100 shipped in the states.
what year/engine size transmission type man or automatic.memcal are you looking for ?
Engine: Lb9
Transmission: M20
Re: Ecm
I could burn you a copy of the 89 no ninth injector, vats delete aujm. It would be a starter tune and you should datalog to refine the tune.
Engine: Lb9
Transmission: M20
Re: Ecm
$100 for the ecm and $55 for the memcal. If that works send me a pm with your address.
my paypal is brianlvs@yahoo.com
The ecm should be fine since it’s a new reman. If it does show up doa
If you let me keep $15 out of the $100 to cover shipping you can use it as a core.
does that sounds reasonable?
Engine: Lb9
Transmission: M20
Re: Ecm
Incase your unaware , you need a 2k ppm signal to the ecm. Was the car tbi or tpi or a v6 before the swap ? Assuming your using the same transmission.
andyiroc88
Jun 18, 2005 09:57 PM
