[TX] Rear Brake Line
Car: 1987 Chevrolet IROC-Z Camaro
Engine: LB9 > L98 5.7-liter V-8 TPI
Transmission: MD8 4-Speed Automatic MX0
Axle/Gears: GU5 3.23 G92
Rear Brake Line
Does anyone have a rear left hand steel brake line? Preferably a take off from a 1987 Camaro (IROC-Z)
Thank you,
James
Thank you,
James
Re: Rear Brake Line
I'm sorry i completely forgot to add that info... disc and 9 bolt
Re: Rear Brake Line
Just looked, thought I had a spare one on a 10-bolt drum rear, but aside from not being what you need, the driver's side on my spare rear has a flat section from a tie-down or pull chain being wrapped around the axle tube.
The disc brake lines should be available from Inline Tube, Classic Tube, RightStuff Detailing, etc. The resto places, Summit, etc should have em in steel or stainless. If you have the original that you can copy, you might be able to bend straight sticks of brake tube from the parts store, and crimp the ends you need.
On the resto reproduction lines, you'll have to be careful you get the right ones for a 9-bolt, iron or aluminum calipers (HD brakes), and choose between stock style steel and stainless.
Re: Rear Brake Line
Gotcha! Thanks again Drew
suchamoneypit
Nov 4, 2017 09:36 PM
cowansauto
Brakes
Sep 28, 2013 08:16 PM
