[WY] I need a high speed 10 bolt ring and pinion
Old May 9, 2019 | 02:54 AM
Samsampson's Avatar
Car: 86 trans am
Im in the middle of a diesel swap and am looking for tall gears for my 7.5 rear. I have a 2.56 set, but if you have something taller let me know.
thanks in advance
sam
Old May 10, 2019 | 09:44 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: I need a high speed 10 bolt ring and pinion
That's probably the lowest numerical gear you can get for the 7.5" 10 bolt
Old May 10, 2019 | 11:54 AM
Samsampson's Avatar
Car: 86 trans am
I found a 2.29 ($175) and a 2.14 ($275) on ebay. I figured someone here may have one more reasonably priced that's just laying around from a gear swap on an old axle. I've seen pictures of a 2.09, but have no idea what it was put in originally.
Old May 11, 2019 | 01:13 PM
firebirddude142's Avatar
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
I prolly got this used
Old May 11, 2019 | 04:53 PM
Samsampson's Avatar
Car: 86 trans am
Used is all I can find, if you have something you want to make some money off of that's collecting dust let me know.
Old May 16, 2019 | 09:38 PM
pontiac_guy's Avatar
You can get a 2.14 from a G body. There was one available on gbody forum.
Old May 16, 2019 | 10:28 PM
Samsampson's Avatar
Car: 86 trans am
Awesome thanks!! I'll go search
Old May 18, 2019 | 04:09 PM
geardaddy's Avatar
Car: 66 chevyll
Engine: blown alcohol injected
I have a set of 2.29.........612-309-3999....................612-309-3999
Old Jul 5, 2019 | 03:37 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Diesel swap huh? is there a build thread or sth, let me know thx
Old Jul 7, 2019 | 07:49 PM
Samsampson's Avatar
Car: 86 trans am
Got one ordered from a member here! I dont have a buildup on it yet, but so far I'm pulling the 700r4 and putting in a 200-4r from my 1983 delta 88 diesel.
It's a 86 trans am, the 305 is gone.
The 6.2 has diamond pre cups that I'll ceramic coat, not so much for performance, but to compensate for the Chinese metallurgy. .010 over head gaskets and a spare 7.3 super duty turbo I have laying around. The pedestal mount style will make changing parts in it easy, and there are plenty of housings and compressor wheels to choose from.
Still pricing out the 200-4r rebuild. Not quite as cheap as the ole 700, that's for sure. I'd like a reverse pattern manual valve body that retains the TV. I'll start a build up when I get this axle, trans and engine assembled. I'm pretty stoked!
UltRoadWarrior9
Sep 2, 2015 08:24 PM
ambainb
Feb 20, 2014 01:12 PM
Keoman
Aftermarket Product Review
Apr 14, 2013 09:39 AM
Camarogeddon
May 31, 2012 11:03 AM
irocyourpants
Apr 26, 2008 07:07 PM
