Engine Mounts Needed
Car: 1985 Camaro IROC Lear Sieger
Transmission: 700R4 Automatic overdrive
I'm looking for engine mounts for a V8. Specifically the brackets that bolt to the K-member and the engine themselves. I can get the clamshells no problem, but the brackets do not appear to be available aftermarket.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Engine Mounts Needed
Buy New motor mounts,... they are about $10 each new at almost any parts store. ( motor mount is bolted to the K member )
https://www.autozone.com/external-en...153593_0_12553
If you need clam-shells,... I've got a couple pairs available. ( Clam-shell is mounted to the block )
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
ThirdGen84Coupe
Oct 11, 2019 01:06 PM
