9 inch diff or 12 bolt wanted 82 camaro
Old Jul 16, 2020 | 04:33 PM
aussiesteve's Avatar
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
Looking for an allready setup 9 inch ford rear or 12 bolt Gm diff for an 82 camaro
Or even a Dana setup...
I need Stock locating brackets and suspension points so i can put it right in and prefered 3.25;1 or 3.36;1
LSD or Possi centre prefered
ANYTHING below 3.42.
but not a big deal if i need to change the gears.
Stock length and disc or drum brakes not a problem.
Car is currently running original 7.65 inch diff with eaton trutrac and 3.42 gears and 26 spline axles that need replacing,(one is bent and needs repairing where the bearing sits) not worth fixing.
the gears are too steep and need to go to 3.25 for highway runs and by the time i spend all that money on this old diff that could break at the strip anytime i could do it right and swap it..
Car runs a Brand new 520Hp 383 AFR setup i had built by Klein Engines AZ.
If you have a diff can it be shipped to Long Beach California or Compton California.
I Pay ALL costs naturally.
Steve.
InfernalVortex
Feb 20, 2016 11:01 PM
jfroh1992
Oct 11, 2010 10:12 AM
87TAairlineyard
Jan 13, 2006 05:01 PM
wyclefsirocz
May 26, 2003 07:49 PM
CHCKLS
Aftermarket Product Review
Apr 27, 2001 04:31 PM
