will nova axle gears fit in my camaro
Old Oct 10, 2010 | 10:46 PM
jfroh1992's Avatar
Car: 91 RS, 93 k1500
Transmission: T5, NV3500
Axle/Gears: stock
ive come across a set of brand new 4:11 gears from a 60s nova 10 bolt that i can get really cheap. i know the axles are different between the two cars but are the insides the same?
Old Oct 10, 2010 | 11:04 PM
Drew's Avatar
Re: will nova axle gears fit in my camaro
Probably not... The old Nova is probably not a 7.5" 10 bolt. Besides that, the gears are the cheap part. Where it gets expensive is the install, and the carrier if it has to be changed.
Unless someone's changed the rear end, your 87 Iroc should have a 3.27 limited slip 9 bolt. If so you need gears for a Borg Warner 9 bolt.
Old Oct 10, 2010 | 11:12 PM
jfroh1992's Avatar
Axle/Gears: stock
i figured they are different but i dont know much about axles so i just wanted to know for sure
Old Oct 11, 2010 | 10:12 AM
big gear head's Avatar
The old Nova rear end is a 8.2 10 bolt. Your car has the 7.5 10 bolt. The only parts that will interchange are a few bearings. No other parts will work.
jklein337
Sep 19, 2018 06:23 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
Vintageracer
Aug 11, 2015 08:13 PM
