10 bolt people only- come on in
Old May 25, 2003 | 01:29 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
hey whats upi'm a little curious one what times everybody is running on there 10 bolts w/ what mos to it about about how much poer your pushoing threw it,
thanks alot---
Old May 25, 2003 | 05:18 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I built the rearend in this white camaro: http://sethirdgen.org/multimedia/rusty02.avi
And yes, thats a Z06 he's running up against
For those who have dial-up, it ran a 12.65 @ 108.8 on slicks. He made several passes that day, and never had a lick of trouble from the rear since then. I used a stock, unwelded housing, New Eaton Posi, GM 3.73 gears, Moser Axles and an aluminum cover (girdle).
Old May 25, 2003 | 05:31 PM
Engine: peanut LB9
is that the 7.5" 10bolt??????
cause heres what i'm planning-
moser axles
moser bearings
auburn pro posi unit
3.42 gears
that should hold a 14 sec 305. i hope
oh and that was a nice run, the strt could of been a lil better but still a goodrun. i like close races
Old May 25, 2003 | 05:38 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yup, thats a 7.5" 10-bolt from an '83 Z-28, I built it myself.
Alot of it depends on who builds it. I have seen some take mad abuse and hold up fine, and I have seen 15 second cars go through rear after rear after rear... There are other things that can help as well, like welding the axle tubes to the housing and (I never used one, but everybody raves about them) solid pinion spacers.
Old May 25, 2003 | 05:46 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
my 10 bolt has held up well so far to 12.0-12.2 passes, on cheaters, just foot braking it...... no real test for it thankfully.. no slicks yet.
it's an honest 7.5" set of gm 3.73's.. a handmedown from a friend of mine. i have the backlash set very tight on them, running an auburn pro posi, and stock everything else.
~playing with fire~
Old May 25, 2003 | 10:19 PM
MdFormula350's Avatar
[QUOTE]Originally posted by GMTech
[B]I aluminum cover (girdle). an aluminum cover (girdle).
would that be this cover? Cover, Differential AAM Cast Aluminum
i am looking to change my fluid soon and was wondering is this a good one to get?
also slp state "Minor modifications to the axle housing are necessary to take advantage of the cooling capabilities of the cover" what did u have to do actually?
Old May 25, 2003 | 10:38 PM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
[QUOTE]Originally posted by MdFormula350
[B]
i recommend getting this cover. will give you extra insurance and is a good buy for our rear ends.
http://www.jegs.com/cgi-bin/ncommerc...46&prmenbr=361
nick
Old May 25, 2003 | 11:04 PM
wow that does look awesome, thanks; any mods to know about for proper fitment?
with or w/o brace?
619-101-7.5G Jegs 10-Bolt 7.5 $139.99
619-301-7.5G Ultimate 10-Bolt 7.5 $154.99
Old May 26, 2003 | 12:38 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
That's not a girdle cover; don't waste $ on that. A girdle will have two studs which help support the bearing caps.
Old May 26, 2003 | 05:53 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes, they are correct, I used the one w/ the supports and the pre-load studs. The one pictured above is just a fancy stock replacement. I didn't have to do any mods to my housing or cover, mine came from Summit.
Old May 26, 2003 | 09:08 AM
Car: 1992 Camaro RS
with or w/o brace?
the difference between the two are:
the ultimate you can add a axle tube kit to to stop the axle tubes from moving about an extra 130 dollars which is a goo investment for the 7.5 but you don't have to get it if you don't want . here is a link to the page of what i'm talking about.
http://www.jegs.com/cgi-bin/ncommerc...47&prmenbr=361
Jegs doesn't have the holes for the setup
hope this helps
nick
Old May 26, 2003 | 11:06 AM
Engine: peanut LB9
does anybody have a pic of that rearend cover with the brace kit? cause that is the only thing i'm waiting on doing to my rearend.
Old May 26, 2003 | 11:23 AM
jmd's Avatar
jmd
http://www.google.com/search?hl=en&l...rential+girdle
Old May 26, 2003 | 05:24 PM
Car: 1992 Camaro RS
not a camaro but you'll get the idea i found this doing a search.
Nick
http://www.corral.net/projects/deepfreeze/dflpw.html
Old May 26, 2003 | 05:31 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I have it on my car ...
HOWEVER, as I mentioned in your other post, don't invest in the 10-bolt. It's the biggest mistake I ever made. Why invest close to 2K in a crappy 10-bolt when you can buy something better. Yes, 10-bolts can last into the 1.5-1.6 60ft range at the track on cars running in the 11's. No big deal ... hahaha ... until you put a manual tranny in front of it. Automatic trannys are soft and don't shock the driveline. That's why you can get away with 1.5-1.6 60ft times. But, put a manual in there and you will shatter the ring and pinion.
Tim
Old May 26, 2003 | 07:49 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yeah, we only spent about $1,000 to build up that rearend. If your going to spend $2K+ , you may as well get a 12-bolt or 9"
deracer
Apr 11, 2016 12:04 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
angel2794
Sep 8, 2015 06:22 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
red90IROCls1
Aug 25, 2015 06:56 AM
