TPI Serpentine bracket needed
Old Nov 20, 2020 | 07:19 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Need this Bracket: Seems like a stupid thing I could delete,... but I really need to find 1 !!
So far I've only found it on a 91Z28 TPI. I am working on an 88 TPI and I don't seem to have it and can't be sure it was ever installed on the 88 ( MAF, cold start ) set-up. Will not be on TBI cars. It bolts to the right-side AC compressor mounting stud/bolt on the back of the serpentine bracket at one end and to the lower mounting hole on the front of the TPI intake manifold on the other end.
Send me a PM ASAP if you've got one you can spare.
Old Dec 5, 2020 | 03:52 PM
John in RI's Avatar
Re: TPI Serpentine bracket needed
bump !
Old Dec 5, 2020 | 04:59 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Early 1988 used 6 total, 3 on each side. Later years they dropped the lower brackets on each side and kept 4 total. 2 middle and 2 uppers. TPIs of course
Old Aug 10, 2023 | 07:24 PM
John in RI's Avatar
TPI Serpentine Rod type bracket needed
OK,..... I need another one of these !! Pretty sure it was mounted to the 90-92 cars. Need the rod/bracket and the 10mm bolt that holds it to the intake. ( I need the rod more than the bolt ! ) Additional pics from another members post for clarity:
Thanx in advance !
Drac0nic
Nov 6, 2016 10:02 PM
jamon8
Jan 11, 2010 08:45 AM
ProChrgdTa
May 4, 2003 08:43 PM
