[PA] PBR Rear Caliper Parking Brake Return Spring
Old Apr 10, 2021 | 09:08 AM
rhodges's Avatar
Want a title? Post!
I am looking for the large parking brake return spring used on the PBR rear calipers. I'm not sure if they are side specific but if so I need the right side. I'm sure this subject has been worn out on here but I feel like I have exhausted all other option other than to resort to begging. If you have 1 or 2 that you are willing to sell please let me know. If you have an old worn out PBR caliper that still has the spring on it and you don't want to sell the spring alone I would consider purchasing the entire caliper as well.
Thanks!!
Old Sep 22, 2021 | 06:57 PM
iroc_you's Avatar
Car: 1984 z28 h.o l69
Engine: 355
Transmission: t5
Axle/Gears: 3.73 posi
Re: PBR Rear Caliper Parking Brake Return Spring
Did you ever find anything?
Old Sep 24, 2021 | 09:57 AM
firebirddude142's Avatar
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
Thanks!!
i may have this got a pic of what your looking for?
Old Feb 1, 2022 | 05:03 AM
Overtemp927's Avatar
Im after a RH Spring...if someone is after a LH Spring.
PBR Park Brake Lever Return Spring
LH sample is the correct orientation. The spring arm helps to keep the lever aligned
namdlo
Brakes
Feb 14, 2019 06:03 PM
Z06 FAN
Brakes
Oct 1, 2013 08:13 PM
hardyz13
Brakes
Apr 20, 2010 07:29 PM
89RESTO
Brakes
Oct 5, 2008 09:03 PM
JoshDT91
Jan 25, 2003 11:14 AM
