Need mount bracket/top plate of motor mount
Old May 29, 2021 | 02:16 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Looking for the 2 brackets that bolt to the eng. that ride the clam shell mounts on the K member..
Lost one of mine..so looking for a 1 not pitted out.
Jeff
Old May 29, 2021 | 07:08 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Need mount bracket/top plate of motor mount
There is a pass and a drivers side clamshell,... so be sure to check yours so you know what you have and what you need.
Old May 30, 2021 | 12:05 AM
good to know..do ya have any?
Old May 30, 2021 | 09:42 AM
John in RI's Avatar
I'll check next time I'm in the garage,...... need a pass or drivers side ??
Old May 30, 2021 | 09:45 AM
looks to be the Passenger side Im missing.. Ill set up the mounts i still have on my GM K member. with some poly upgrades..just in case the the other mounts on the way don't work.
Need Passenger Side.
Old Jun 1, 2021 | 10:16 AM
John in RI's Avatar
I do not,...... checked yesterday & I've got 3 shorties (EDIT: driver side ) !!!
Old Jun 2, 2021 | 11:24 AM
thanks for looking.. got it fixed with solid Mounts By Trans Dapt.. still want the GM bracket. so I can do a Poly Mount setup..
dennisbernal91z
Feb 23, 2014 11:36 AM
TNSS
Feb 13, 2013 12:45 PM
Skarddd
Exterior Parts Wanted
Apr 28, 2012 04:45 PM
Stephen
Fabrication
92
Jan 1, 2012 08:01 PM
SoSoFresh_SS
Jun 20, 2009 06:31 PM
