Axle Tubes from a broken disc brake rear
Old Dec 20, 2021 | 01:42 PM
Sdmodified's Avatar
Car: 1991 Camaro RS
Engine: LS3 w/ HCI
Transmission: Magnum F (T56)
Axle/Gears: 4th gen 3:42 posi rear
want to fab up an 8.8 but need to find thirdgen length axle tubes that can use my LS1 brakes. HAve a good fourth gen rear but want to sell it and go back to thirdgen spacing.
So if anyone has a blown up 10 bolt with disc brake ends, that isn't rusted to ****, and you want to chop the tubes off flush with pumpkin, let me know. Or, if you are in the NJ area, I can just pick-up and chop myself.
Old Dec 22, 2021 | 01:56 AM
geardaddy's Avatar
Car: 66 chevyll
Engine: blown alcohol injected
Re: Axle Tubes from a broken disc brake rear
i have several "new" 4th gen axle housings i would love to get rid of.""cheap""..give me a call at 612-309-3999..................612-309-3999
Old Dec 23, 2021 | 11:22 AM
Sdmodified's Avatar
Car: 1991 Camaro RS
Engine: LS3 w/ HCI
Thanks for letting me know. I will be keeping you in mind. Downside to using a 4th gen donor is that I would need to cut off all the mounts, have the 8.8 built to 3rd gen width, then weld all the mounts back on at the correct 3rd gen locations.
But, it might prove pretty difficult to find a junk 3rd gen disc brake rear that isn't rusted to hell.
jjcuff1
Jul 23, 2013 12:01 PM
Dens71TA
May 12, 2011 09:04 PM
RegnittoFormula
Brakes
Jun 17, 2007 08:18 PM
Crusin' 1980's
Brakes
Apr 24, 2006 09:48 AM
maksik7
Aug 3, 2001 07:13 PM
