92 Camaro A/C condenser
Car: 92 Camaro RS
Engine: V6 3.1
Transmission: 5 speed
I am looking for a A/C condenser for a 1992 Camaro. Please note that late 91 may work but prior years to 91 will not as they changed the fitting locations and sizes.
Car: 1990 GTA
Re: 92 Camaro A/C condenser
Do you have any pictures of this cause I’ve never seen a different condenser and when you say fitting are you talking the refrigerant ports and/or pressure switch?
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Lots of little things changed on late 91.5 to 92 F-body cars and it got to be more changes as time went on from 91.5 until the end came for the 3rd gen.
We got parallel flow condensers and other AC system changes. Makes it nice to do a R134a conversion.
Our cars are glued together with structural adhesive and have more spot welds and in different places, My car has rubber rub strips on the body in the hatch area to prevent squeaking, new redesigned silicone impregnated weather striping. T-tops with redesigned weather striping. The later cars are much better built than the pre 91.5 F-body cars. Way stiffer, way less squeaks, rattles, moans, and groans and better fit and finish.
My T-top car sat in my driveway during the Noah's Ark rains we just had and is dry as a bone inside.
Car: 92 Camaro RS
Engine: V6 3.1
It is hard for me to take a photo because the condenser is still in the car but if you check RockAuto, the part numbers for i.e.86 are different than for 92. If I remember correctly, something about the fitting size that's different.
They have the AC condenser you need on Rock Auto.
The application guide for the 4 different AC condensers they have listed is either 1991 - 1992 Camaro and 1992 Firebird, or 1992 Camaro or Firebird
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Engine: 5.0
If I jump the gun, I apologize. Every single parts wanted that got spammed with the same message today. I got scammed by a similarly worded response last year here. I'm leery of anything that directs you to use contact information outside of the chats or messaging feature here. My apologies if it's legitimate
