305 TPI to 73 350 Rocket Carbed Swap
Old Apr 15, 2002 | 02:51 AM
TAsRBAD's Avatar
I need to know what i will need to do with my ignition system, exhaust(will it match up?), fuel system(I have an electric pump now and will it work with an Edlebrock 750cfm?), also does the 350 turbo tranny use the same length dtiveshaft that my current 700r4 use?, and what about motor mounts? Your help would be greatly appreciated guys. THANKS
Old Apr 15, 2002 | 12:07 PM
TAsRBAD's Avatar
Any help from someone would be greatly appreciated. come on guys!
Old Apr 15, 2002 | 01:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
To keep it simple, you would have to do something to everything you listed. And, probably some more. All of it will be custom made, nothing will be available off-the-shelf.
The easiest part is a regulator to drop the fuel pressure from the in-tank electric pump. Otherwise, you're looking at time-consuming, specially-made, most likely expensive parts to put in an over-weight, under-powered engine.
Ever consider a "real" 350? Honestly, that's the much better choice.
Saturday, my first run ever with my mods was a 15.77 at 5800' Bandimere - with a tranny that wouldn't shift from 2nd to 3rd and my cruise-type gearing. Last year, there was a 3rd gen out there with a Buick 455 that ran 15.25. He went through a bunch of work for that 1/2 second advantage, and by the time I get mine running right, I'll probably be down there, too. I wouldn't call his "different" really worth it - would you?
Old Apr 16, 2002 | 03:02 AM
TAsRBAD's Avatar
Thanks!
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
