Crate Motors
Old Apr 23, 2002 | 09:52 PM
MurphsIroc's Avatar
Crate Motors
hey guys, I am really thinking of getting an entire new engine for my 1988 Iroc Camaro. I have a 110k mile 305TBI that just doesnt cut it. I want to be able to hang with the big boys. I also need something very reliable for I will be Driving about 15 miles a day to and from School. Wha wa as for engines should I go? Wat a *** Crate motor for a cheap price. There is about a 4K budget with this project. I want to keep my 700R4 tran too. Please, any info would be geatly apreciated.
Chris
1988 IrocZ Camaro
Old Apr 23, 2002 | 11:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I would get the chevy 383 HT crate motor if i were you, around $3300. It is a really nice motor with tons of torque.
Old Apr 24, 2002 | 05:30 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I bought the 300 HP TPI 350 crate motor from www.goautocenter.com.
It was $1855 plus shipping.
It's a 93 Caprice 350 short block,with TPI heads and Crane Compucam.Ordered it with the TBI cam.
All new gm with warrantee.
It replaced the 215,000 mile 305 in my 92 RS
Passes smog in CA and pulls hard to 5500.
-Rich-
Old Apr 24, 2002 | 06:05 PM
xxwarrior36xx's Avatar
I agree with the 330 horse 350 it is really cheap has a warantee and you can have alot of fun with it. and if you have all this money to put into it you can do some stuff to it, and make it run even better without hurting your wallet.
Old Apr 24, 2002 | 09:49 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
-Rich-
What kind of numbers did you post with the motor(ET-wise)? You see, right now I'm just putting in suspension parts and fixing the drivetrain; with the goal of eventually throwing in a Ram Jet 350, but those numbers seem real close with that motor for about 1/3 the cost of the Ram Jet. It might be a while though due to the fact that I only have 70K miles on it right now....ahhh to dream:lala:
Old Apr 25, 2002 | 09:35 AM
Car: 92 Camaro RS
No ET yet. Local drag strip is no more. Have to drive a couple of hours to get to a strip now, and can't afford a big towing bill if my T5 comes apart. Planning on Tremec TKO install in June.
Probably in July I should have some real numbers, though my car's really set up more for the twisties than straight-line hook-up.
I was gonna do the Ram Jet also, after seeing one in a thirdgen on the Hot Rod cover, but since I'm in California I need to pass smog and my current setup passes (with stock air cleaner on).
I do have real dyno numbers, however, as a friend of mine has access to one. (not a chassis dyno)
317 HP at 4500 and 398 Ft/Lbs at 2500,flywheel.
That's with 3" cat, single 40 Series Flowmaster and AIR pump,
(no power steering pump or alternator) and the computer and chip I'm using in the car.
I'll post G-Tech numbers when I get one.
-Rich-
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
masonta
Aug 31, 2015 10:14 PM
