Crank identification
Old Apr 28, 2002 | 08:11 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Do anyone have a source where I can Find the Specification for this Crankshaft.
Main Cap#: 3743951, also these # on front two caps 162.
" rear two caps 139.
Old Apr 28, 2002 | 08:49 PM
DTL504's Avatar
The above number are incorrect. I found the right numbers:3815822...348...forged...3.25" stroke and
3815822..265,283,302.forged..small journal....3.00" stroke
Now how do I know which one is correct. this crank has .020 Journals and modification was made to this engine before I bought it. When I first found the engine an old lady was selling her husband that had left her and wanted $200 to get the car out of her yard. I seen the Camel hump heads and thought it was a orginal 327. Then later found out by checking the numbers it was a 283. So how could I determine which crank is the right choice my guess would be the short stroke.
Old May 3, 2002 | 07:58 PM
primo's Avatar
Try the following link:
http://www.mortec.com/
Old May 3, 2002 | 08:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
3815822 was used from 1955-67 in 265 and 283 engines. It's a forged crank with small journals. Both engines used a 3" stroke. They didn't start making large journal cranks for 302's until 1968. My guess is that you have a 283. Not good for anything except to collectors.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
