Might be getting a V8..I have some Questions.
Old May 7, 2002 | 11:32 AM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
My buddy at church just got a 1971 Buick LeSabre to jump around in because he was rearended in his Saturn. His dad found him this car so he can have some wheels until he gets a new car.
I just spoke to him for a few minutes and he said that the car has a monster V8. He didn't know what the cubic inches were. I asked him what he was going to do with the car once he gets a new one because I would like to have the engine to put into my 84 S/E V6 car.
My questions:
-What is the V8 in the 71 Buicks? Will they fit into thirdgens?
-The car only has 107 miles on it. Yep an old lady had it and very rarely drove it. Im thinking a 107 mile motor for my thirdgen would be great!!! Is there any thing I should look for or replace since the motor sat for 30 years. Is it worth buying from my friend?
I don't know the what kind of shape the car is in or what the motor is but if any one knows any info on the Buick motors. Let me know!
I will try and update you all on this when I get more info.
Old May 7, 2002 | 01:20 PM
86 sc's Avatar
best thing to do is get the casting numbers off the block, and then do a internet search, find a site that you can run threw the numbers and find out, you can also use the vin nuber for that
Old May 7, 2002 | 02:15 PM
TBurke's Avatar
I'm not sure what motor it is but. You will have alot of headaches trying to get parts to work in a 3rd gen. Go with a 350 small block if you want to do a swap.
Old May 14, 2002 | 10:12 PM
79Z's Avatar
79Z
You're buddy's '71 LeSabre will have either a 350 or a 455(not sure if Buick still built their 400 in '71),The 455 will be wider than the 350.If it's a 350 4 barrel it will make real good power,I had one in a '73 Regal back in the late 70's and it was a mover for a big car. Tip of the day,"a 455 Buick weighs almost exactly the same as a small block Chevy"...believe it or not.If they can fit Pontiac engines in third gen's a Buick will fit.A Buick is the only GM V8(other than a Cadillac) that has the distributor in the front....usually a "plus" in a tight swap.You'll have to probably weld up some mounts but anything can be swapped in if you have enough time,money,ambition and persistence.I once helped a guy put a '67 430 Buick into a '72 MonteCarlo.
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
apie2546
Sep 20, 2015 01:03 PM
