#993 sbc heads
Old May 13, 2002 | 07:10 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
#993 sbc heads
How would these perform on a 327ci with flat top piston ?
3998993....72-73...307/350......75cc chambers
3998993....current..350.........Goodwrench crate motors,"Hecho en Mexico",75cc chambers
Old May 13, 2002 | 08:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
<insert gagging sounds here>
You'll end up with a ridiculously low CR, and no flow. In other words, a dog.
Old May 13, 2002 | 11:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They're good castings but would have low compression ratio for a 327 with flat tops. They're better suited for a 350 or 400.
Old May 14, 2002 | 04:35 AM
Engine: 406
Thanks Guys, thats all I needed to know...have a great day. Im going to go with World Sportsman II. Im thinking 64cc chambers, what ya think?
Old May 14, 2002 | 12:33 PM
iroc22's Avatar
64cc is a more reasonable #. It's just about right with flat tops on a 327.
Old May 16, 2002 | 01:07 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You can get a good street compression ratio with these heads on a 327 if you have them flat milled .060".
This should reduce the chamber volume to 67cc's.
On a .030" over flat top 327 that is "0 decked" , using a felpro .039"
gasket,, your cr will be 9.4 :1... If the piston is .025" below
deck use a .015" shim gasket (factory type).
They will give good flow when ported.
evilstuie
Jan 9, 2020 08:29 PM
CRFred
Feb 7, 2016 11:39 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
