Are Sterling Hypereutectic Pistons any good?
Old May 16, 2002 | 10:09 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I am planning on building a mild 350 street motor so I have decided on hyperutectic pistons. Are the Sterling Hypereutectic Pistons any good? Here is a link to summit's site: http://store.summitracing.com/produc...earchtype=ecat
Its a little bit odd that some cast aluminum pistons cost more than these hyperutectic.
Old May 17, 2002 | 08:12 PM
kevinc's Avatar
Car: 1982 Z28
At the marine engine shop I worked at in high school there were two cheap-azz pistons they'd use for low buck rebuilds: Badger and Sterling. The builders hated them...big variations in weight, poor packaging and they'd arrive damaged, etc.
You can do better for very close to the same price with Keith Black or Federal Mogul. I'm running FM H631P 2 valve relief 5.7" rod hypers and no complaints after 3 years.
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
