1996 Block Question
Old May 19, 2002 | 07:50 PM
360Iroc's Avatar
1996 Block Question
I am unfamiliar with the newer blocks, because I have only used the older ones. A buddy of mine has a 1996 roller block out of a Truck, is this going to work with 1987 TPI equipment? If it is that would be great. What are the changes in these? Is there reverse cooling in this block? Help is greatly appreciated...Thanks in advance...
Old May 19, 2002 | 10:21 PM
Tas's Avatar
Tas
1996 was the first year for vortec. If it has the heads on it still, he'll need to get the special vortec TPI lower manifold. Vortec truck engines should have roller cams. No reverse flow cooling.
Old May 19, 2002 | 10:33 PM
360Iroc's Avatar
The heads are not going to be used so would this be a go?
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
